Brief Description: cut elevator push rod to length and fit end fittin
Cut elevator push rod to length and added end fitting. Trial fit to elevator and realized dimension of rod included end fittings, so had to recut the push rod. Still need to fit bushings into F* and F9 for elevator control rod. Still need to mount push rod bushings at F8 and F9
Cut 2" from each rudder control push rod and re-tapped both rods.
