Brief Description: located rudder pedals and checked layout
in cockpit for first time to check rudder pedal location. Decided to move rudder pedals 2"closer and decided to move pedals in 1/2" to make sure they cleared F3. Moved pedal feet inboard 1/2". Measured and match drilled mount plate to bottom skin. Drilled and bolted feet using AN526 8-32 machine screws. Cut slots in F3 for extension rods. created clamp plate for rudder cable ends. Temporarily fit cable to rudder pedal extension. Extension rod will need to be shortened by about 2" and re-threaded. When fabricating clamp plate, drawing showed cable slot should be 3/16" During first fit up measurement showed 1/4" was correct dimension.
