Deburred and riveted both spars and then clamped, drilled and riveted pre-made ribs to form stabilizer internal structure. Set stabilzer frame onto rear fuselage, located, squared and then drilled mount holes in spars and longerons.
stabilizer spars assembled and bolt stiffeners added
set stabilzer spar in place and drilled mount holes
