Removed temporary center wing floor and used it as template to drill .032" sheet. Cut .032" sheet to size drilled all holes and match drilled to center ribs. Cut access hole in floor and began shaping cover plate and support ring. Match drilled support ring in place for rivets and then match drilled cover plate to ring for screws.
cntr wing flipped over showing floor and access plate
