Brief Description: fit left wing ribs and rear spar
mounted all left wing spars. Fit F-1 and F-7 using setting tool, then mounted rear spar and fit remaining ribs to rear spar. Bent flange on wing bottom and began fitting it to left wing ribs. Drilled rear spar. Marked wing bottom to match ribs and drilled skin.
