Brief Description: layed out and cut wing leading edge and bent curve
Layed out left wing leading edge, cut to size and bent curve per plans.
The leading edge skin radius is formed by folding over the skin to within 1/2" to 3/4" of the bottom side and pressing down on it with a 2 by 4 as shown in the manual. If you try to match up the top edge with the bottom edge the skin will come up short as it wraps around the top of the ribs. If you match up the top edge with the bottom to within 1/2" to 3/4" the skin will fit without any triming.
