Brief Description: located, adapted and attached 2" inlet to carb hea
Cut down 4" aluminum sleeve to make adaptor flange, but abandoned it. Located 2" flanged aluminum vents and adapted them for use. Rvieted same to carb heat box. Saved remainder for use with heat shrouds and cabin heat box.
Before ordering and obtaining 2" flange from A.S. I found 2" aluminum vents as shown in photo. I removed the baffle on outside and was lift with flanged piece as attached to box. AS flange is also shown
