smoothed and bent carb heat box. Obtained 22ga steel sheet an 1/8" rod. Fabbed door and beazed rod to it. Assembled carb heat box with door installed, added wire screen and foam filter. Still need 2" heater hose connection at top of box Before ordering and obtaining 2" flange from A.S. I found 2" aluminum vents as shown in photo. I removed the baffle on outside and was lift with flanged piece as attached to box. AS flange is also shown
