EDWARD'S WEB SITE
Date:  11-10-2010
Number of Hours:  3.00
Brief Description:  riveted fin spar
Countersank top rivet joint on spar. Deburred spar angles and web, clecoed and flush riveted. Drilled lower fin hinge 5/16" for bushing. Cut and shaped fin upper hinge bracket. Located and drilled 5/16" hole for bushing. Verified fit of upper fin rib into spar.
lower fin hinge & spcr
Fin spar with upper rib
Fin spar w lower hinge bracket
