DOUGs Web Site
Sling 2
Central Fuselage
4-16-2018
Rear spar assembly
Assembled the rear spar with clecos, bolted and riveted together. The bolt holes had to be enlarged from .183" to .189" for the bolts to fit. The bottom 4 holes on either side are left un-riveted for elevator stops later.
rear spar cleco assembly
riveted and ready for next assy
bottom 4 holes left for later
Sling 2 Home
705
109
Central Fuselage
86
138
Elevator
Horiz Stabilizer
Rear Fuselage
63
101
Shop & Tools
Undercarriage
Vertical Stabilizer
172
