DOUGs Web Site
Sling 2
Central Fuselage
4-15-2018
Reworked spar angle mounts
I drilled out the main spar angle mounts, reversed them to the correct orientation, and then riveted back in place. I also riveted the back landing gear uprights. I'll finish the front ones when I get a jig from TAF.
Drilled out 20 rivets
Mission Accomplished.
riveted back landing gear uprights
Sling 2 Home
705
109
Central Fuselage
86
138
Elevator
Horiz Stabilizer
Rear Fuselage
63
101
Shop & Tools
Undercarriage
Vertical Stabilizer
172
