Today I moved the rear fuselage into position behind the central fuselage, hung the front end from the garage door opener with a tie-down strap, and supported the rear with a saw horse. I then proceded to move the rear fuselage into position while simultaneously making sure all of the mating surfaces were going where they needed to go. This required a lot of shims to guide skins and channels over or under mating skins.
