DOUGs Web Site
Date:  3-24-2019
Number of Hours:  0.50
Brief Description:  2 - fit vertical stabilizer
I applied torque seal to all of the elevator hinge nuts.
I removed the rudder from the vertical stabilizer and then fit the stab to the tail with clecos. I then connected the tail posiition / strobe light and VOR antenna connectors. I'll need to clean up the wiring with some tie wraps later.
torque seal applied to elevator hinge nuts
vertical stabilizer clecod in place
connected light and antenna
