DOUGs Web Site
Sling 2
1 - Drilled new wire routing holes in rudder
The wire routing in the rudder was not clearly explained in the manual, but after looking at other builders sites, I found the correct way.
I removed the rivets and the fiberglass cap from the rudder and drilled new grommet holes for the wire routing.
removed rivets and rudder cap
drilled wire exit hole
drilled new entrance hole
Sling 2 Home
705
109
Central Fuselage
86
138
Elevator
Horiz Stabilizer
Rear Fuselage
63
101
Shop & Tools
Undercarriage
Vertical Stabilizer
172
