DOUGs Web Site
Sling 2
1 - installed connector jack on elevator trim serv
I found some 6-pin DIN style connectors with screw shell to use on some intermediate connections.
I used one for the trim servo connection.
I stripped the wires, pretinned the connections, solder the wires to the jack and then finished the assembly with heat shrink tubing.
configured pinout for servo
soldered wires to jack
heat shrinked connections
Sling 2 Home
705
109
Central Fuselage
86
138
Elevator
Horiz Stabilizer
Rear Fuselage
63
101
Shop & Tools
Undercarriage
Vertical Stabilizer
172
