DOUGs Web Site
Date:  2-19-2019
Number of Hours:  1.00
Brief Description:  Installed static source tubing and water reservoir
I cut the two static port tubing runs to equal length, installed the straight fittings with tie-wraps, connected the tee with tie wraps, routed the tubing and secured in place with tie wraps.
While I was in the tie-wrapping mood, I went ahead and installed the Rotax water reservoir to the firewall with tie-wraps.
static port fittings installed
tee installed and tubing routed
zip-tied the water reservoir
