DOUGs Web Site
Date:  12-20-2018
Number of Hours:  1.00
Brief Description:  Firewall Foam insulation fitment
I removed the cardboard template from the firewall, aligned it to the firex foam material and then cut it to shape with a razor and scissors. I then measured, cut and fit the side pieces for the motor mount channel.
Fit looks pretty good. I then marked all of the through holes needed with an awl and circled the areas with a sharpie pen.
I bought a fairly inexpensive set of punches for soft materials on Amazon, and will cut the hole when the tools arrive.
cutting foam with template
test fitting foam insulation
hole punch set
hole punch set
