Brief Description: 2 - Removed right tank and cleaned excess sealant
The right tank came off a lot easier now that I know to use a shim to cut the skin loose from the spar. I removed the excess sealant from the tank with a plastic knife and scotch brite, and deburred all of the holes that I had previously matched drilled.
