DOUGs Web Site
Sling 2
Set fuel level sender floats
I fit the fuel level senders in the tanks, adjusted the angle of the bend arm for the float and then made final adustments by bending the two metal stops on the sender.
I'll loctite the float arm screws before I do final installation.
Fit fuel level senders
Adjusted "empty" position
adjusted "full" position
Sling 2 Home
705
109
Central Fuselage
86
138
Elevator
Horiz Stabilizer
Rear Fuselage
63
101
Shop & Tools
Undercarriage
Vertical Stabilizer
172
