DOUGs Web Site
Date:  5-24-2018
Number of Hours:  1.50
Brief Description:  1 - Central/Rear fuselage joining
Today I moved the rear fuselage into position behind the central fuselage, hung the front end from the garage door opener with a tie-down strap, and supported the rear with a saw horse. I then proceded to move the rear fuselage into position while simultaneously making sure all of the mating surfaces were going where they needed to go. This required a lot of shims to guide skins and channels over or under mating skins.
suspended rear fuselage
moving into position
closing the gap
closing the gap
