DOUGs Web Site
Date:  5-20-2018
Number of Hours:  0.50
Brief Description:  1 - Clecod and drilled holes for controls cover br
I clecod the brackets for the rear controls cover and then drilled the remaining holes in the skins. One rivet hole at the left end in figure two was marked, as I will need to remove the panel in order drill.
outboard brackets
outboard brackets
inboard brackets
inboard brackets
