DOUGs Web Site
Date:  5-16-2018
Number of Hours:  0.50
Brief Description:  8 - wire and coax routing
I routed the com and nav antenna coax through the longerons. The com antenna coax is really short, so I may put a junction or run new coax. I also routed the strobe and eleveator trim wire through the longerons.
All of the wires and coax are just test fitted and not tied down at this point. I may put some plastic protective wrap around them.
com & nav coax, strobe & trim wire routed
wire routed for tail connection
