DOUGs Web Site
Date:  5-2-2018
Number of Hours:  0.50
Brief Description:  6 - mounted right wheel & tire to axle
I inflated the tire / tube to 2.5 bar (37 psi) and then deflated to 1.5 bar (22 psi). I looked up the tire pressure on the web for the 6.00-6 x6 ply and it is 42 psi for 1750lb load. I'll need to look in the Sling manual to find the actual recommended running pressure.
right wheel installed
2 down, 1 to go!
2 down, 1 to go!
