DOUGs Web Site
Date:  4-29-2018
Number of Hours:  1.30
Brief Description:  Riveted rear inside panels
I removed the plastic film from the two rear inside panels and riveted the braces to them. One of the brackets on both sides of the cockpit were installed incorrectly, so i drilled out the rivets and re-installed them correctly. I then clecod both panels in place.
riveted braces to rear inside panel
bracket on wrong side, moved
rear inside panels clecod in place
