DOUGs Web Site
Date:  4-25-2018
Brief Description:  Completed, Riveted Vertical Stabilizer Frame
I riveted the frame together with the replacement angle I received from TAF. The fit was pretty good (much better than before.) I opened up the M3 rivnut clearance holes a bit to prevent any problems later. I then installed the VOR antenna with mount. Its now ready for strobe and antenna wire routing and then final covering of the skin.
Frame riveted and ready for Antenna
Antenna / mount riveted in place
