Andrews Web Site
Date:  2-26-2012
Number of Hours:  3.00
Brief Description:  Final Weld of Control Horns
Did the final weld on the elevator control horns. This is the weld that needed to extend deep between the plates. I ran a full weld bead rather than small partial beads. I found this weld to be right on the limit of my capability at present. I wish I had more welding experience. I showed some of the welds to welding experts at work and they are happy that the welds are structurally fine....but I am far from a master welder.
Showing finish welded horns
Alignment check
Alignment check
Welds look decent....not perfect .  (some practice welds in background)
