Fabricated the rudder bottom rib. After cutting and marking the blank the first step is to form the joggle. This could maybe be done on the bending brake with some skill and luck needed because the bends are so close together and need to be at the right angle. Seeing how I have little skill and very little luck, I cheated and rolled the joggle. Next step is to make some form blocks and beat the joggled part into submission.
