Brief Description: Continued Rib fitting and stiffener additions
There are lots of stiffeners to be added to the ribs. These are all being fitted and riveted at this time. Image 1 shows left wing inboard ribs with the .063 angles that are needed for wing walk strength. Image two shows strings that were added to the nose ribs on the right wing to assist in tweaking the final angle of the ribs. (This will be a fuel sealed surface, so I am trying to get a flawless interface for the flange locations and angles) Image 3 shows the formed trailing edge ribs that will be installed at BL: 16.5 and 24.5
