Continued working on the lower fin hinge. I fabricated the spacer, and angle fitting that nests in the hing to provide the rudder limit stops. I aligned the hinge to the centerline of the spar and drilled for 3/16 bolts. Fabricated the little weldmet at the nose of the fin
Showing limit stop before I drilled the stop bolt holes
