Well, It's been about a month since my last entry. I was out of the country for 2 weeks, then when I returned I was out of the city for 1 week. I guess it doesn't matter much, It's about 900 degrees in the garage anyway. So enough excuses, I did make a little progress. I continued putting in the ribs and brackets on the left side of the tail. I also started lining up the aft reinforcement plate (shown in image 3) The bolt from fuselage through root rib will be drilled along the zero degree incidence line.
LH Mid Rib brackets and Installation
Inboard Rib brackets and Installation
The laser line is the spar neutral line at zero degrees incidence. Tape is longeron location.
