Andrews Web Site
Date:  5-7-2011
Number of Hours:  3.00
Brief Description:  Drilling aft spar hinges
Drilled hinges onto the aft Hz tail spar. the space between hinges is supposed to be 0.45 inches, so I made a spacer block to make the setup constant and parallel. I also used the temporary set-up pins available through Avery tools (Avery is located on my airport, so it's easy to get things that may be useful.
Wood spacer block being used to set hinge spacing
22.25 hing drilled
22.25 hing drilled
Spar taking shape
Spar taking shape
