Andrews Web Site
Date:  12-12-2023
Number of Hours:  16.00
Brief Description:  Bellcrank and Elevator Autopilot Servo mount
The design of the servo mounting was finalized and the brackets were fabricated. Image 1 shows the completed bellcrank arm. The hole near the bottom is where the autopilot servo linkage will attach. Image 2 shows the bellcrank mounting arms and the servo mount plate. The mounting plate will rivet to the right bellcrank mounting, the floor and the bulkhead. (should be a very stiff mount) It is made from .063 2024T3.
Elevator Bellcrank fabricated
New bellcrank and servo mount
