Brief Description: Lower intersection splice skin bend finalization
Work continued on the lower skin. First the upward bent flange needed to be fine-tuned to get the edges to perfectly align with the slice flanges located on the outboard ends of the flap torque tubes. Next the large bends on the aft side needed to be adjusted to fit tightly around the skin on the aft fuselage. Once satisfied all was well, then the 90-degree flange was bent on the upper side to align with stiffeners in the forward and aft fuselage. Finally, all of the seat rib flanges were drilled as well as the double rows of fasteners next to the bulkhead flanges.
