Brief Description: Prepping for roll servo installation
As mentioned previously, I have decided to add the roll trim servo similar to what Dick used. However, it appears that with some of the other modifications Dick made to the fuselage supports, the mounting pad for the servo on the blueprints is not workable. As an alternative, I made the mounting pad shown in the pictures below. Also, the servo I am using (Ray Allen T2-7A) has shorter throw than the one Dick used. This is because I happened to have this servo on hand and didn't want to buy a new one. This should give me about half the trim capability that Dick has. It's better than nothing, but I may end up swapping out to a longer throw sometime after flying it a while if it bothers me. As mentioned earlier, I do not have roll trim on my RV-4, and when there is a rolling tendency, it just gives me a notice that I need to switch fuel tanks. I would hope the Nexus is the same.
