Brief Description: Riveting various forward fuselage parts
Riveted the forward double row of rivets at FS:33.125. Some of the rivets between the two 33.125 bulkhead halves were hard to reach and set properly...but persistence prevailed. For a change I went back to finish the riveting on the baggage door. I obviously over killed the number of rivets used in the inside skin. and I am too cheap to use CherryMax rivets for that many locations, so I tried to use as many solid rivets as possible. You can see in image 3 that the majority are solid, but it was impossible to do everything.
