Brief Description: Started assembly of the forward fuselage
Started working on the assembly of some of the forward fuselage parts. Image 1 shows the longerons riveted to the engine mount fittings. Image 2 shows the riveting of the center section to the spar angles. The Numatx squeezer just fit in this space. Image 3 shows one of the side skins after proseal was added at the firewall interface. The skin was mounted to the firewall and rivets set while everything was wet. By the way, I continue to dislike the mess made when working with proseal. It gets all over everything!
