Brief Description: Upper Engine Mount Fitting Modifications
Similar to the modifications made on the lower engine mount brackets, I added flanges that allow for a 90 degree intersection on the mounting plate. This should allow a better weld while decreasing the Heat Affected Zone (HAZ). Since this bracket needs to interface with a U shaped channel, I am decreasing the overall width of the bracket to fit more tightly on the bolt. I also welded the entire perimeter of the two flanges to ensure they act as a unit, although this is probably overkill.
