Brief Description: Upper seat belt anchor and skin doublers
Drilled the upper seat belt anchor into the upper longeron. Also started to look at where the .025 skin doublers for the side longeron will go. Still trying to decide if the aft doubler should lap under of over the aft bulkhead flange. The plans show it over the flange. This will require a joggle, and will limit the amount of edge distance I can get on the forward horizontal stabilizer attach bolt. I may just lap the doubler between the bulkhead and skin. that is done on the aft baggage compartment bulkhead and it does not seem to put much of a bump in the skin. Also, notice that the forward doubler is not symmetrical. This is because I am interfacing with the hole patter in the bulkhead.
Aft stiffner lapping between bulkhead and skin (not as shown on plans
Upper seat belt anchor drilled
Looking at where doublers will go. Tape is longeron location.
