Brief Description: Removed Aft Fuselage From Fixture
Removed the fuselage from the fixture. Then disassembled the fixture and stored the major components in case they can later be used when aligning the aft fuselage to the forward section. Spent some time imporving the fit of some of the bulkheads (rebending flanges etc) Also started to rough cut the right side skin.
Aft Fuselage Out of Fixture
Showing Bulkheads. (Blue alignment Tape still showing)
