Brief Description: Continuing alignement and initial bulkhead rigging
When installing the 82.625 bulkhead, there are three dimensions that define it's position FS 84.5 at the top (canopy interface) FS 82.625 at the reference waterline and FS 79.375 at the bottom (rear seat interface). Based on where these points are located on the bulkhead, they will not result in a straight line. Therefore, something appears to be wrong on the BP. I suspect the 82.625 dimension might apply at the top longeron, not the reference waterline. At any rate, I have an email in to Dick Eaves on this. Improper placement of this feature would result in a domino effect on the rest of the bulkhead locations.
Somewhat arbitrary reference line on each bulkhead 82.625 support
Using the water level to establish reference lines at either end of the fixture
