Brief Description: Continued prep of bending brake
Cleaned, painted and added aluminum tape for final surface of angles. Began preparation of work bench to hold sheet metal brake. This required stiffenting the edge by adding doublers and support struts. Also extended the base to make sure the bench does not want to tip over with all that weight located near the edge.
