Andrews Web Site
Date:  4-19-2023
Number of Hours:  8.00
Brief Description:  Day 1 Right leading edge sealing
Started the sealing process for the right-wing leading edge. The instructions that Dick wrote for this phase were very complete. Day 1 involves painting sealant on the skin surface for the upper surface of the ribs only. Image 2 shows paining sealant on the rib upper surface. (Yes, this seems redundant and may result in some excess, but this is one of the rare cases when I would rather take the weight penalty and reduce the chance for a very difficult to correct leak)
Image 3 shows the skin after rivets have been set in the spar and clecos are inserted in every rib hole. (Note: I also put quite a few clecos in the bottom surface as well just to make sure that the skin was pulled down around the leading edge properly)
Sealant on skin inside upper surface
Sealant on ribs and spar
Skin in place
Skin in place
