Continued working the skins for both flaps. Image 1 shows the final bend for the right flap. Image 2 shows the rib forms that I used as reference to guide the bending of the nose skin. Finally, Image 3 shows the nose skin in place and ready for drilling. I tucked the skin under the top skin to use as a guide for drilling. This meant I needed to be careful not to bow the spar in any way to ensure good alignment with the existing holes. It worked pretty well. Any remaining misalignment will be cleaned up when drilling holes up to final size.
