Andrews Web Site
Date:  8-26-2022
Number of Hours:  12.00
Brief Description:  Continued working leading edge drilling
Drilled the final holes in the wing leading edges. Image 1 shows hole alignment when looking through the holes that were located using the template (fairly decent alignment with desired location). Image 2 shows the right wing skin with spar holes, final tip trip and fuel tank filler cap all located. Image 3 shows the drain bung location as well as the final trim on the inboard edge including the access panel notch.
Showing alignment of template holes to rib
Showing filler cap location
inboard edge trims and bung location
