Brief Description: Continued drilling wing leading edge skins
Continued working on the leading edge skin rib holes. Image 1 shows drilling the rib holes per the pattern locations as well as simple 90 degree locations for the ribs that are free to be adjusted. Image 2 shows the right wing ribs full drilled with spar yet to be completed. Image 3 shows both wing ribs drilled
