Brief Description: Fuel tank access cover fabrication
Covers were cut out of .063 stock for the fuel tanks and match drilled with the .125 fittings that are located inside the tanks. Image 1 shows the right cover drilled to its tank fitting, and the left tank cover has yet to be drilled.
