Brief Description: Fitting Flap brackets to rear spar
Drilled the flap brackets into the wing. It probably does not matter exactly where these pivot points are located as long as the flap pivot points are built to match. Never-the-less, I spent quite a bit of time struggling with their location. I ended up establishing a set of plumb bobs from the spar with appropriate offsets measured and adjusted to ensure consistency.
