Brief Description: Right Outbd Aileron Bracket Installation
Installed the right wing outboard aileron attach bracket. This was made difficult because of the many interferences with my wing support fixture. After the fixture was modified, other modifications had to be made to get good fit at the aft flange. Additionally, I previously had installed a bracket to attach the rib to spar. This bracket was now incompatible with the aileron attach bracket and needed to be remade. Also, the resulting holes in the rib were not in a spot compatible with the new bracket. Instead of making a new rib to accommodate the now dead holes, I simply made a thicker and larger attach bracket that picked up more holes while supporting the rib. (there will be extra, unused holes in the rib under the bracket)
