Brief Description: Inbd Aileron Attach point Rigging
More detail on the inboard aileron attach bracket installation. Getting the pivot point in the right location is reasonably important. (Although later adjustments can be made in the aileron bracket location) To do the best I could, I made sure the spar was level (although the wing washout varies this slightly) and the pivot point was located a measured distance from the spar lower flange.
Pivot location from flange (not supposed to be in center)
