Andrews Web Site
Date:  5-10-2022
Number of Hours:  15.00
Brief Description:  Right wing details
I have been doing all the same things to the left wing that I already showed on the right wing. (Bracket installation and stiffener riveting) Image 1 shows Today, I finished the bracketry and moved on to the forward spar. Image 1 shows some of the left wing stiffeners riveted on in the area of the wing walk. Image 2 shows the initial formed spar for the outboard spar. There are the normal minor twists in the ribs and other things that will need to be attended to in order to get a good fit. These adjustments are time consuming, but don't make for interesting pictures and comments in a construction log. The left wing flapper door is shown in image 3.
Left wing stiffeners riveted (typical)
Left wing forward spar fabrication
Left wing flapper completed and riveted in place
